PINPOINT TEST RW: REAR WINDOW WIPER
RW8 CHECK REAR WIPER PARK POSITION
l Key ON.
l Operate the rear wiper.
l When the rear wiper is out of the park position turn the key OFF.
l Disconnect the rear wiper motor connector.
l Measure the resistance between the "BL" wire terminal on the rear wiper motor
and ground.
l Reconnect the rear wiper motor connector.
l Key ON.
l When the rear wiper is in the park position turn the key OFF.
and ground.
l Is the resistance less than 5 ohms with the rear wiper in a position other
than park, and greater than 10,000 ohms with the rear wiper in the park
position?
Yes
REPLACE the rear wiper motor.
No
REPAIR the rear wiper motor case ground.
