PINPOINT TEST RWS: REAR WASHER SYSTEM
RWS4 CHECK POWER SUPPLY TO REAR WASHER MOTOR
l Key OFF.
l Disconnect the rear washer motor connector.
l Key ON.
l Measure the voltage of the "BL/O" wire at the rear washer motor connector.
l Is the voltage greater than 10 volts?
Yes
GO to «RWS5».
No
SERVICE the "BL/O" wire.
