PINPOINT TEST RWS: REAR WASHER SYSTEM
RWS6 CHECK WIRE BETWEEN REAR WASHER MOTOR AND REAR WIPER/WASHER SWITCH
l Key OFF.
l Disconnect the rear washer motor connector and the rear wiper/washer switch
connector.
l Measure the resistance of the "GN/BK" wire between the rear washer motor
connector and the rear wiper/washer switch connector.
connector and ground.
l Is the resistance less than 5 ohms between the rear washer motor connector and
the rear wiper/washer switch connector, and greater than 10,000 ohms between the
rear washer motor connector and ground?
Yes
Go to «RWS7».
No
SERVICE the "GN/BK" wire.
