Reclining Mechanism
Removal
1. Remove the seat side cover.
2. Remove the hog ring securing the seat back trim over the reclining mechanism.
3. Slide the seat back trim up to expose the reclining mechanism and seat
back bolt.
4. Remove the seat back bolt.
5. Recline the seat to a position where the upper and lower reclining
mechanism bolts are accessible.
6. Remove the upper and lower reclining mechanism bolts.
7. Remove the reclining mechanism.
Installation
To install, reverse the removal procedure.
Tighten the upper and lower reclining mechanism bolts to 34-44 N-m (25-35
lb-ft).
