SPECIFICATIONS
GENERAL SPECIFICATIONS
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Item ³ Function ³ Specification ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ High pressure (discharge) side ³ System pressure ³ 199-220 psi ³
³ Low pressure (suction) side ³ System pressure ³ 19-25 psi ³
³ Refrigerant pressure switch ("BK/W"-"Y/GN") ³ Closed between ³ 206 ñ 20 kPa
(30 ñ 3 ³
³ ³ ³ and 2648 ñ 193 kPa psi) ³
³ ³ ³ (348 ñ 28 psi) ³
³ Thermostatic switch ³ Cycling range ³ Open at 25øC (77øF) ³
³ ³ ³ closed at 0øC (32øF) ³
³ Refrigerant system ³ Oil capacity ³ 300 ml (10 fluid oz.) ³
³ Refrigerant system ³ Refrigerant type ³ Refrigerant 12 (R-12) ³
³ Refrigerant system ³ Oil type ³ C9AZ-19557-B ³
³ ³ ³ (Motorcraft YN-2) ³
³ Refrigerant system ³ Refrigerant capacity ³ 0.7 kg (1 lb. 9 oz.) ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
