System Inspection -- Front Washer System
          VISUAL INSPECTION CHART
1. Visually inspect the following components of the front washer system:
        Mechanical:
Damaged front washer fluid reservoir
Blocked, clogged, cracked or deteriorated washer Hose
Binding front washer motor
Electrical:
Blown fuse:- 15A WIPER
Loose or corroded connections
Damaged wiring harness
Damaged front washer motor
Damaged front wiper/washer switch
