System Inspection -- Front Washer System
1. Visually inspect the following components of the front washer system:
VISUAL INSPECTION CHART
Mechanical Cause
Blocked
clogged
cracked
deteriorated washer Hose
Binding front washer motor
Damaged front washer fluid reservoir
Electrical Cause
Blown fuse:- 15A WIPER
Loose or corroded connections
Damaged wiring harness
Damaged front washer motor
Damaged front wiper/washer switch
