System Inspection -- Front Window Wipers
1. Visually inspect the following components of the front window wipers.
VISUAL INSPECTION CHART
Mechanical  Cause                                         Electrical Cause
Binding or seized front wiper motor             Blown fuse:15A WIPER
Binding front wiper arms                     Loose or corroded connections
                                                            Damaged wiring harness ³
                                                          Damaged front wiper motor ³
                                                    Damaged front wiper/washer switch
