System Inspection -- Rear Window Wiper
1. Visually inspect the following components of the rear window wiper.
VISUAL INSPECTION CHART
Mechanical Cause
Blocked
clogged
cracked
deteriorated washer hose
Binding rear washer motor
Damaged rear washer fluid reservoir
Electrical Cause
Blown fuse:- 15A R. WIPER
Loose or corroded connections
Damaged wiring harness
Damaged rear washer motor
Damaged rear wiper/washer switch
