Washer Nozzles
The washer nozzles are held tight against the sheet metal by a two-pronged
spring clip that is part of the nozzle.
To remove a nozzle, the clip must be collapsed before it will pass through the
hole in the sheet metal. In most cases, the clip will be damaged during removal.
Ensure a replacement nozzle is available before attempting to remove a washer
nozzle.
