Wide-Open Throttle Position
1. Adjust the accelerator cable deflection as outlined in this section.
2. Depress the accelerator to the floor.
3. Confirm that the throttle plate is in the wide-open position in the throttle
body.
4. If necessary, loosen the locknut and adjust the pedal stop on the pedal
bracket.
5. Tighten the locknut after the adjustment is completed.
*Copyright © 2003 Ford Festiva Com-All Rights Reserved
