Wiper Blade
Removal
1. Turn the ignition switch alternately to the ON and OFF positions while the
wiper switch is on until the wiper arm is in an upright (vertical) position.
2. Rotate the wiper blade so that it is perpendicular with the wiper arm.
3. Using a screwdriver, press the tab to release the hooked end of the wiper arm
from the wiper blade holder.
4. Disengage the hooked end of the wiper arm by pulling down on the wiper
blade frame.
5. Separate the wiper blade from the wiper arm.
Installation
To install, reverse the removal procedure.
