I was in Tom's shoes. With a stuck axle in a man trans festiva. 5 hours or so of wedging, chiseling, prying, pulling, two at a time. ETC ETC :angry1: This morning I solved it. I wanted a slide hammer. Advance has them but not the c part Jay mentioned. I found the tool online but couldn't get it in time. Deadline was tomorrow morning. So I made this....
One cable on each side for even pressure. I made sure to pull perfectly straight. I had already tried unsuccessfully at a slight angle when something was in my way. So I moved said thing and pulled straight. I had about 4 feet of slack in the cable too for a long stroke. I also put the "big tuning fork" that I had been using to pry between the cross member and the trans to support the trans and prevent the motor and trans mounts from absorbing the shock and stealing the force I was exerting. I yanked and on the 4th or 5th pull she popped out. Mine was stuck so fiercely because it is brand new. Last week new axle, same day new seal leak. Today I got it out, replaced the seal and it's back on.
