I found a festiva on Craigs list For $100 . They told me a ball joint went out so they put new LCAs on it. Shortly after that something happened to the front end again and it was making a terrible scrapping noise. They had to limp the car home on the shoulder at 25 MPH and parked it as they were scared to drive it any more. Sure enough it was making a horrible noise. Took a look under the car and found this
The backing plate had come off the front knucke and was laying on the brake disk. Yanked it out and problem was solved, no tools needed.
Drove it home ( 40 Miles ) without issue. A/C worked good. 140,000 miles nice running motor and smooth tranny. Came with two extra tires and two dash mats. Has four good tires newer battery, timing belt has been replaced. The PO had owned it since 1992
