Camber Plates Round 2...
Not totally satisfied with the first install I bought another pair. This time for a 02-07WRX.
02-07' WRX Plates as Delivered
Bolted both together ensuring any modification would be equal on both sides.
Traced on the original Festiva strut mount. Then simply cut along the lines and drilled
an extra hole on the far end.
Installed!
And I will say handling is dramatically improved. Been out to the track a few times since
the install. The extra camber has helped tremendously with cornering and the pillow ball
mounts give such a direct feel to the steering.
- Chris
Installed!
- Chris
