well i gave up trying to find one of the factory latches...
ford escorts have a light under the hood that turns on when you open it up. The light has a built in mercury switch. So i canibalized one so i just had the mercurey switch
![](http://i34.photobucket.com/albums/d130/stefanranda/IMG_1354.jpg)
and i wired it in so it switched the ground.
![](http://i34.photobucket.com/albums/d130/stefanranda/IMG_1356.jpg)
![](http://i34.photobucket.com/albums/d130/stefanranda/IMG_1359.jpg)
then i figured out what angle it switched on at.
then i zip tied it inside that hatch at the appropriate angle so it grounds when the hatch is lifted.
![](http://i34.photobucket.com/albums/d130/stefanranda/IMG_1361.jpg)
![](http://i34.photobucket.com/albums/d130/stefanranda/IMG_1362.jpg)
and there you go! its very easy to make and works great.
