well i gave up trying to find one of the factory latches...
ford escorts have a light under the hood that turns on when you open it up. The light has a built in mercury switch. So i canibalized one so i just had the mercurey switch
and i wired it in so it switched the ground.
then i figured out what angle it switched on at.
then i zip tied it inside that hatch at the appropriate angle so it grounds when the hatch is lifted.
and there you go! its very easy to make and works great.
