My 1989 Ford Festiva (Carb) is losing power. I am driving on the freeway and it lost power when I turned off the car and tried to turn it back on. The battery is 465CCA (Mine)/525CCA (Brand New) and tested Good. The alternator is pumping out 14volts to the battery so that is good also. I Drove on the freeway last night and the car's lights and interior lights were all dimming. The Heater/Cooler wouldn't turn on when I tried to power it on also (Never noticed that before). But somedays the car will work just fine. Today I drove and it drove "Normal", but sometimes it loses power. Can anyone help? Thanks
My Festiva is losing power
Try replacing the Fusable links like in this thread http://www.fordfestiva.com/forums/sh...=fusable+links My head lights would go out then I replaced the Fusable links and it no longer does it.'90 LX
Originally posted by mdswsu View PostMy 1989 Ford Festiva (Carb) is losing power. I am driving on the freeway and it lost power when I turned off the car and tried to turn it back on. The battery is 465CCA (Mine)/525CCA (Brand New) and tested Good. The alternator is pumping out 14volts to the battery so that is good also. I Drove on the freeway last night and the car's lights and interior lights were all dimming. The Heater/Cooler wouldn't turn on when I tried to power it on also (Never noticed that before). But somedays the car will work just fine. Today I drove and it drove "Normal", but sometimes it loses power. Can anyone help? Thanks"FLTG4LIFE" @FINALLEVEL , "PBH"
If the alternator is putting out a steady 14 volts, either the regulator is bad, the battery is dying, or the fusable link is bad. May also be corroded battery cables as addressed above.Chuck
Life's a beach, then you marry one---- Shakespeare
If money will fix it, it's not broken
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
http://www.fuelly.com/car/ford/festi...tfordcat/54176
http://www.fuelly.com/car/ford/festi...tfordcat/54596
How long has it been (if you know) since the plugs, wires, button, cap, etc. were changed? In other words, is it time for a tune up? You lost power when you turned it off. Did it restart? Right away, or did it need some cool down time? Sudden loss of power, or gradual draw down?
1988 L - 232K miles BatstivaDumb thieves go to prison, smart ones go to work for the Government.
ok, ok hold on here. first get yourself a digital multi-meter (thery're cheap, and worth every penny). then start your car. check the votage at idle and off idle (should be close to the same). then turn on EVERYTHING (lights, blower, radio, defrost if you have it, wipers on low, etc.) check voltage again... should not be below 13.4 volts. if it is, check again off idle and notice any change (if voltage goes up to above 13.6, then you're in good shape provided the voltage never drops below 12.8 )Trees aren't kind to me...
if everything is electrically in good shape, and you still lack power at highway speeds, get a new coil (accell super coil).Trees aren't kind to me...
Festivabot, did you test the alt in car as discribed above? AZ doesn;t use this protical and their method won't show if the alt dies under load.Trees aren't kind to me...
Ahem.
How about a loose alternator belt? This is one thing that can be revealed by testing it Festyboys way...Contact me for information about Festiva Madness!
My festy had a bad ground (chassi to engine) and I was having sparatic crappy running, the engine /trans found its own ground via the clutch cable and welded its self internally, next time I pushed the clutch in it snapped the cable..... not a good time!
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
