coil over kit cheap and modify?
  • coil over kit cheap and modify?
    Thinking of getting a cheap coilover kit and modifying my rear apsire struts to lower back end of Festiva? From E-bay
    88-00 HONDA CIVIC CRX/INTEGRA JDM RED COILOVERS SPRINGS
    Item condition: New
    Compatibility:
    See compatible vehicles
    Time left: 19d 14h (Mar 18, 201104:25:13 EDT)
    Price: US $26.99
    Approximately C $26.44
    Any one have input?
    Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
    Someone told me CRX springs are way too short and you might be riding on bump stops
    88 Festy L (The White Thunder)
    91 L came and gone, owned only 2 days
      Sounds like a minimum of 7" from what I have been reading?
        I'm trying to find the thread someone told me about it. I'm not completely positive but I believe that's what it said. If you are reading otherwise, then I say go for it!
          If that's the typical eBay Honda kit, the spring rates are waaaay to stiff for a Festiva. The rest of the kit is probably usable, but you need to get softer springs.
            could you use your stock springs???
            1992 white L, Bp, American racing 13's, stock trans.
            1991 White L, BP/F5MR, protege header, full aspire swap with gr2's, seats, and sway bar, 15" konig's, short throw, escort console.
            1991 blue L, 5 speed.
            1988 red L-plus-all stock.
              ^ Not with the typical coil over kit.
              Check this write up out.
                Good write up! so what do you think total cost on that would be?
                  my bad just saw it says 300
                    would these work???
                    just the sleeves dont have two locking keys?
                      I would make sure to ask if those are aluminum top hats, etc. No cheap plastic parts.
                        Basically the adjusters are what a fellow needs and then try to find springs at the 100 lb and 150 lb rate. I am going to keep looking till I find a kit like that.
                        Yes "Safety Guy" I really do not want plastic pieces.
                        Some one will sell them?
                          every single kit i have encountered has aluminum top hats, plastic top hats would mean lawsuits
                          I wouldnt say the civic springs are to hard for a festiva, depending on what you want
                          what do you want to get out of the coilovers? do you just want to lower the stance for looks as a daily driver? or are you planning to autox/track the car?
                            I would email all those vendors and see if they stock any various springs. I hate buying from several people, you pay more with shipping that way.
                            1993 GL 5 speed
                              Chrisofna up in Canada just got a set of coil overs with PLASTIC tophats. Check this thread out:
                              Apparently he lost a dispute with the ebay seller on the issue.
                              I mentioned them above since I recall Nate (Skeeter) saying something about them being sold by some sellers and to make sure of all the materials before buying.
