OHIOSTIVA PLANNING THREAD: Only 2.5 weeks away!
  • #61
    ^ dang it I was waiting to see your ride because I like it I'm in the boom boom room changing the hub on my b6 because im having some issues. Ill be rollin in it if me and kevins plans dont work out.
    Is this all that's comming? I thought it was gonna be more cars?
    • #62
      As it sits now lol ill have to do a thread on it I have done a lil bit to it.
      • #63
        I like the roof rack, bring it to Ohiostiva you can get it fixed
        • #64
          " racks on racks" lol I'm gana try idk if its mt thermostat or water pump just doesn't stay at normal temp always goes past and I don't wana blow my head gasket so idk gana try thermostat first if that fails then I'm doing a water pump ill try to get it finished by ohiostiva but idk
          • #65
            Make sure your fan is kicking on I know it sounds stupid but it happened to me. My fan fuse blew and didn't even know it till my rad exploded lol. Unhook your temp sensor and it will default to run constant if it doesn't them its a fuse or the pump like you said.
            • #66
              Is there anything food/supplies that is not covered? I'd like to bring something
              1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
              Rocketchips!
              Bolt-on Weber Carb Adapters!
              • #67
                Damnnnnnnnnnn how could I be so stupid hahaha I didn't even put the fan on after putting in a new radiator FACE PALM!!!well I know what I'm doing when I get home tomorrow lol
                • #68
                  hahaha
                  -Rafe-
                  Things I have for sale.
                  Random Festiva Parts
                  • #69
                    By the way I did a little quick thread lol http://www.fordfestiva.com/forums/sh...574#post595574
                    Just so info and pics on what I have done so far.
                    • #70
                      ummmmmm.... I hope you really are just making fun of me and you really didnt forget the fan..... I can handle the banter but I really hope you didnt forget the fan
                      • #71
                        No. I really did forget haha I'm restarted lol
                        • #72
                          Well put that junk in and get that thing to ohiostiva its littterally a 15 min job
                          • #73
                            My luck is I put the fan in and it still doesn't stay cold but ill prolly be replacing the thermostat anyways and hopefully that's the problem
                            • #74
                              ^ in the name of father john it will work lol. No but seriously that fan makes a huge difference
                              • #75
                                Lol I bet lol cause before it was fine then after my buddy broke it by stepping on the radiator when it was out I had to get another and it didnt have a fan and I didn't think anything of it didnt even remember and forgot the damn fan so ill find out tomorrow lol hope it works!
