place to put ground
  • place to put ground
    i'm putting subs in the festy and doing the install. Where is a good point to have a quality ground for the amp?
    Thanks...
    The sub (or subs if they fit) are 12 inch massive comps. The amp i'm running is a JL a1800
    Proud owner of Casper
    Well there is alot of places just put it to a good bare metal spot to frame.
      like the frame bolt that ties the rear seat down....
        That would work perfectly.
          I used the rear seat bolt as well. Works great, and you can hide the ground under the carpet.
