Has anyone here ever wired in a battery isolator for a second battery?
Battery isolator
Yes, got one from the local Car Audio shop, is like $50 buck. I hook all the amps & capacitor on second batteryThe line up -
2016 Focus RS
2005 Mini Cooper S
1995 Turbo Mustang
1986 Buick Grand National
1991 Escort GT (Daily)
1980 Fiesta
How exactly did you wire it in?
It came with a bunch of possible wiring diagrams, none that match what I have.
Essentially, they want you to wire it into the alternator. They say that there should be a plug with orange and black, and red and black wires to re-rout to the isolator... Mine is not at all like that. I have a white wire (alone big plug) And a red and black wire on their own plug off the side or the alt...
Mon arme a moi, c'est un stylo.
will be the white wire, unhook it from the alternator and tape it up not use, run a new wire from that to the isolator, leave the main battery positive cable hook up than add a new cable run it to the isolator, same for the second battery.The line up -
2016 Focus RS
2005 Mini Cooper S
1995 Turbo Mustang
1980 Fiesta
The closest diagram I found is this. (it does specify 1998 and later fords though? My car is a 92...)
The part that really twists my noodle is the "excitor" connection (E) that I should send to a 6amp circuit breaker, then to an ignition run connection in the fuse center???? WTF?Mon arme a moi, c'est un stylo.
All Group 2 Isolators may be used in Group 1 applications. Simply disregard the additional excitation ("E")
terminal. A Group 2 Isolator will have a colored fourth terminal indicating the "E" terminal.
This is needlessly complicated. I'm going to go talk to the rv guys.Mon arme a moi, c'est un stylo.
