i just got a jvc sk124 and wired it up. i got every thing wired and turned it on and all it did was try to eject something and shut off. thats all it will do. do u think its wired up wrong or is it a bad stereo??
problems hooking up head unit
Sounds like something is messed up inside. Is this an older unit? A search at the JVC site turned up nothing with that number.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Id double check you hot wires make sure youve got them correct. 1 will be constant power to hold memory and time when car is off and the other is actual power when the key is turned on. double chack and make sure your grounds are good as well.
Also make sure there wasnt some sort of transport screw in the unit that was supposed to come out before installation.Some manufactures put them in.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
I had 2 old jvc's do the same thing to me, but they weren't new......Contact me for information about Festiva Madness!
Youve still got something wrong. You shouldnt have them both running to the same source.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Constant (Yellow wire typically) should be connected to something that is always live, Switched (red wire Typically) gets connected to something that gets switched on when the key is turned on.
Sounds like you have both hooked up to what only the switched (typically Red) should be hooked up to.Previous owner of a '89 Graphite L, 4spd, GL Seats, Aspire Brakes, 14x6's, 185/60/14's
Originally posted by damieni just got it working. i had to run the memory and the power main on the same wire, the constant source. it works but my memory still doesn't work. do u know y??"FLTG4LIFE" @FINALLEVEL , "PBH"
