what size are the stock speakers?
  • what size are the stock speakers?
    I am looking to get different front and rear speakers for my festy, what size stock are they?
    I know they are small.
    -Aspire brake swap COMPLETE!
    4 inch front and rear.
      3.5" up front and 4" in back.
      Youre right gotta. I was thinking 3.5 up front because thats what Ive put in previously.
      - Unknown
      - Quentin Crisp
      - Bumper Sticker
        I cant find the wiring for my drivers side rear anywhere....
        91GL BP/F3A with boost
          did you remove the rear plastic pannel and check for it? should branch off the impact fuel cutoff harness
          89SX funtop! Fully loaded!
          RIP 90LX
            According to my brother who does custom stereo installs. You can put 5.25s in front and rear. But only 2 screws will hold them in place. He said the way Festivas are laid out in the dash is very similar to some Toyotas hes worked on and it sounded a LOT better with the 5.25s. In fact so much better he said dont waste your time with the 4" speakers.
            - Unknown
            - Quentin Crisp
            - Bumper Sticker
              I put 5 1/4's in mine. It took very little modification. On the rear hatch portion you'll have to use long screws with springs, use the screw holes closest to the sides and the screw hole for the luggage cover clamps. Works well with no vibration.
                pics!!
                  ARGGHHH. No camera. Wife keeps it clutched tight to her chest.
                    i got 4's in front and 6's in back...
                    1989
                    Ford Festiva L
                    Automatic
                      door speakers
                      Are the door speakers holes for 4-1/4" ?
                        You can put 5.25 or 6.5's in the doors. I have 6.5 Kickers in mine.
                        Jerry
                        Team Lightning
                        Owner of Team Lightning
                        93 L Lightning. BP
                          don't forget 6.5 in the doors will require spacers so the window will clear them.
                          -Zack
                            Mine fit without spacers. No issues with window operation.
                            Jerry
                            Team Lightning
                            93 L Lightning. BP
                              if you get a spreaker with a big magnet on the back of it, it will hit the glass... the ones i wanted to put in had a huge magnet in them and would hit even with a 3/4 inch spacer... i had to stick a 1/4 inch spacer on the ones i have now... but if you get a "thin" speaker it will fit just fine...
                              you can fit 6.5 inch in the back and 4 inch in the front (without cutting up the dash...) you CAN fit 5.25 in the dash but you have to cut the dash up... and you can fit 6.5 inch in the doors.
                              Mike, AKA the sasquatch
