backup memory?
  • backup memory?
    My new cd deck has a yellow wire labeled backup memory? what does this go to?
    Proud owner of 92L, 350KM, Home made muffler, sounds like a truck! 16 years without replacement of anything but filters! 5spd EFI, Anyone else's shifter look like its from a quarter-ton?
    Generally speaking, this wire goes to a 12 volt source that is always on.
      what would you recommend? the same circuit as the cigarette lighter?
        i havea black solid wire, with red stripe, what is this for?
          is the black wire on the radio end or the car end? more often than not and according to the haynes manual wiring diagram i just checked, the black wire is the ground wire for the radio. im not real sure about one with a red stripe on it but according to the wiring diagram im looking at it there is a red wire with a black stripe that is for the interior lighting
