More Amps...45 will not feed the SOUNDS!
  • More Amps...45 will not feed the SOUNDS!
    Just became the proud owner of my second Festiva....$200 car with $2000 worth of stereo equipment. Exclusively Kicker Components (except the head unit...Pioneer until I get a Soundgate). Looking for a reliable High Output Alternator to run a Competition system. Present set-up hit at 145.7 with a single 12" Solo X driven by a KX1200.1. Looking to double what I have....System is supported by a 1000 CCA Battery under the hood, an A Shuriken 2250 amp power cell... linked with Kicker 0 guage. Need more mids and tweets....Carbon Fiber headliner filled with Kicker Components on the way. Long project...but needless to say, I'm gonna need more HORSEPOWER.....SO HOOK ME UP WITH SOME LINKS GUYS AND GALS! yupitsahemi@yahoo.com....thanks
    check this thread for info- should point you in the right direction
    -Aspire brake swap COMPLETE!
      Dam you seriously need to post pics!!
      Here's my system:
      I need a better amp but i've hit 143 db
        That setup is sweet. Did you have to completely remove the back seat for that? If so, how hard is that to do? Is there a delete kit, or just a bare spot where the seats were?
        My Fleet:
          Mazda Protege alternator. Easy to find, 70 amps (I think) and dirt cheap.
            I had to completely take out the back seats and the little hooks that the backrests hook into
              Can we assume your system has some aux. humongazoid capacitors to help supply voltage/current to the amps? Farads, baby!
                ^^Yes i have a 1 farad cap with my set-up
                  ^^ Good advice for thumpz, in case there's no such component(s) in that setup.
