Amp/ Battery help
  • Amp/ Battery help
    Very bad at sounds
    The wire connecting to the battery split off.
    The connector to the battery has crud? in it and waqs wondering how to clean out the copper and crud to readd the wire from the amp to the battery
    I would buy a new terminal at a Mc Parts that looks like the original, not the kind that bolts on. As far as the Amp goes, I like to use dual terminal batteries like the group 35/75 shown. This gives you a seperate terminal for you Amp hookup.
    Baking soda, or a can of Coke will clean up the terminals with a scotchbrite pad. Wear gloves so the battery acid doesn't get your hands!!!!
    HTH
    Michael
    Have owned 9 so far
      thanks, yah imma just get a new terminal
