Pioneer TS-WX50 sub
  • Pioneer TS-WX50 sub
    I've just been given a Pioneer TS-WX50 "spare tire" subwoofer. Does anyone have an owner's manual for this or know where I can get one?
    Thanks
    Ian
    Check with pioneer on their website.
    I found one for an older cd receiver on there.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      I tried that earlier with no luck but thanks anyway.
      Ian
        what do you need to know? i have info
          Just need to know the proper hook ups. It appears that all I have to do with it is hook it up to the subwoofer outlet on my Pioneer DEH-P4000UB head unit.
          Ian
            no.
            it is "possible" but don't. get a decent 2 channel amp and bridge the connection to the sub.
            those subs are wired in an 8 ohm configuration (odd) and to get the most sound out, you'll want to bridge it on a non-sub amp (ie. 2 channel) so that it drops to 4 ohm.
              Is it self amplified? Otherwise you will need to use a power amplifier.
              Oscar
                it's not.
                pioneer HU's have a "hey, do you want me to power a sub instead of rears?" option that should have never been put in there.
                  No, I meant if the sub is self amplified. A head unit can't power a sub (even if they claim they can) so if the sub doesn't have a built-in amp, he will need to get one.
                  Oscar
                    and i said it wasn't self-amp'd
                    and you actually can with the pioneers. but i would never recommend it.
                      unless TS thinks that "subwoofer output" is the rca line, then no. won't work.
