hey guys i hooked up my radio n now my gauge lights don't work, any ideas?
radio but no gauge lights
My guess would be that you shorted out the "illumination" wire when hooking up the radio. If so, there is a fuse that should have blown. Check your fuses and get back to us.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Drawing too much current for that fuse.
Didn't think the radio harness was on the gage cluster light circuit.
Don't have my wiring diagrams with me to check.
You might want find another +12v line for the radio or run a dedicated fused line direct to the battery.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by doylerl View PostMy guess would be that you shorted out the "illumination" wire when hooking up the radio.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Does your radio have a dimmer feature? If not, did you cap off the wire in the car's harness that is 12v hot when lights are on? It's green on my 89.
