alternator options
  • alternator options
    i was reading some older threads about audio setups, and was looking at alternator options and alot of people said to do a protege swap, i dont know if it was the only couple i looked at but they were only 65 amps, i got to searching and found an rx7 alternator, looks exactly like the mounting of a protege/festiva alternator...
    heres a ebay link
    03 Chevy S-10 Extreme-4.3
    92 Ford Festiva GL-to be determined
    92 Buick Roadmaster Estate Wagon-5.7
    I'm also wondering about this.
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      the mounts are crazy similar to the festiva/protege alternators...ill have to get one when i figure out were to get an engine for mine...
        Next time I go junk yarding I'll do some comparing for our research!
          sounds good man, there isnt any rx7's around my area or i would do the same
            323 90 amp units...
              Taurus SHO is also 90A, direct bolt/plug in.
              Jim DeAngelis
              kittens give Morbo gas!!
                Very nice options, thanks for the input fellows
                  Would a 88 tracer have the 90 amp in it?
                  Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
                  Dennis
                  93 GL In progress BP/hydro G
                  15 Mitsubishi Mirage daily
                  88 Dakota tow pig
                    Depends ,
                    The 3.2 auto 93-95 is 120A and the model is different then the MTX ones. This is a mitsubishi unit and they are not cheap.
                    the 3.0 MTX is the same for 89-91 and 92-95 its another one , and I believe the later one has more amps....This is a ford unit.
                      Originally posted by PhoenixSHO View Post
                      Depends ,
                      hmm... then maybe what I have is off a Probe. It was labeled '89 SHO in our parts room. It has an '89 part#, is definately a Mitsu unit, stamped 90A...
                      Jim DeAngelis
                        I just looked on rockauto , and I think you are right , the 90 amps seems to be mitsubishi. and the later 130 amps - Ford. For them MTX. The ATX was always a Mitsu , 120 Amps.
                        This is the 90 amps it should look like.
                          Nice, I will check these others out when I head to the junk yards
                            ding, ding, ding!!! We have a winner! Yup, that's it. Mine has no pulley, but the Festy/Aspire pulleys seem to fit nicely.
                            Jim DeAngelis
