wiring for rodio
  • wiring for rodio
    hi guys i recently bought a second hand head unit for my aspire, when i took the old casset player out i found to wires with different connections, 1st one was power. 2nd i presumed was speakers. well on the back of my new head set theres only one port O.o, the new head set came with no wires or any thing so what am i meant to do?
    thanks in advance Sam.
    You need a wiring harness. This one will fit your Festiva.
      Welcome to the forum egg!
      See the sticky at the top of the Audio forum called "Radio Harness Adaptors". Stickies and searchng will save you a lot of time with questions.
      Spiko, he has an Aspire.
        cheers guy, umm well i guess there arent any kind of adapter cables so ill have to chop the connectors off and solder the proper connection on.
          ^ NO!!!! there are adapters for your car, honest to god. gimmie a few and i can find them.
          HERE you go!!
            oops
            Last edited by Chobobulous; 02-15-2012, 01:28 PM. Reason: thought he said he had a festiva
            06 Jeep Cherokee Overland
            95 Aspire (sold)
              C'mon egg, I just pointed you to where the adaptor info is! So did spiko.
                Whoops, read through the post too quickly. There are adapters available. Amazon, eBay, or any car audio store should have them stocked to fit your Aspire.
                  Wal-Mart has them in stock. Those are everywhere
                  1989 Ford Mustang GT 5.slow
                  1996 Ford F-150
                    I read the original post over and it sounds like you don't have the harness adapter for the head unit itself?
                    If so, you can google the model number and come up with the adapter pretty easily. You wire that to the Aspire harness adapter (with solder and heat shrink ideally) and then it should be a plug and play installation.
                    -Zack
                      Good catch, I missed that too! Sorry egg.
                        sorry guys :/, um i had to get 2 cables to make it work, 1 for head unit then 1 from car to other side of head unit cause i couldn't find any in my local area but its all good now, im running 190 watt sony computer speakers with a 8-9 inch sub (all external) i hooked it up with the red and white av cords, sounds fantastic..
                        thanks for your help guys
                        cheers sam
                          I was an unlucky one the black bullet had all stock wiring had adapter and all pulled my headunit and sold car with adapter still in and she took to audio place to get head unit installed and they cut it out and spliced a new sthle harness into stock set up bought car back and went to got install my head unit and it took me nearly 2 hours trying to figure out which set of wires went to which speaker so trust these words of advise go buy adapter and its pre color coded for easy installation good luck
                          89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
                            WALMART!!!!!!!
                            ReD 91 L FIRSTiva
                            92 silver 5spd with some boost! Kratos
