Audio help needed
  • Audio help needed
    I installed a radio in my car yesterday and when my car is running the left front speaker gets a high pitch humming like its my rpms making the noise, when my car is not running but on the radio is crysatl clear. What makes this happen?
    Is one of the wires touching something and i makes that noise?
    www.facebook.com/rhodestiva ;
    rhodestiva@gmail.com ;
    '92 Festiva L M/T
    '93 Festiva GL A/T
    Did you use the factory wiring for everything? Id recheck all connections and make sure no bare wires are touching anything. Make sure you have speakers hooked up correctly. + side to + side, - to -. It makes a difference.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      i will check that this afternoon.
      i read to make sure the alternator is grounded good?
      '92 Festiva L M/T
      '93 Festiva GL A/T
        If you hear the revs through the speaker, it is 100% NO DOUBT a ground issue. You need a better ground. Use a self tapping screw and make a new ground to be sure.
        1990 Festiva L White: R.I.P.
        1988 Festiva L Silver: R.I.P.
        1989 Festiva L White: R.I.P.
          Technically there IS a difference, however you'd NEVER hear it under normal circumstances. Unless you are running speakers in a super close space (Such as in a bandpass box with two subs sharing only one air chamber, like I have in my hatch). If you are running a run of the mill Pioneer deck from Walmart, you are NEVER going to be able to hear a difference if you run your speaker in or out of phase. And running speakers in/out of phase would NEVER have anything to do with hearing the revs through the speaker.
            Hey I started with the basics. Things Id check. After that I wouldnt know what to do, so Id call my brother who installs stereos. Its obvious that you know something more about stereos than I do. So how bout helping him with his problem instead of critiquing my answer to him. Hmmm
            - Unknown
            - Quentin Crisp
            - Bumper Sticker
              Let's not argue it is all good advice to me.
              RUIDD:banana time
              '92 Festiva L M/T
              '93 Festiva GL A/T
                I did give him an answer. It's the ground to your stereo. You just stated to "Make sure you have speakers hooked up correctly. + side to + side, - to -. It makes a difference." I just explained that it really doesn't. And yes, I did full electronic installs on highway patrol cars for a few years. I was just trying to help.
                Once you have done stuff like this, car stereos are easy. It's all like legos, and most electronics issues in the world, can be traced to a problem with the ground.
                  Nice set up and thanks for the explanation.
                  - Unknown
                  - Quentin Crisp
                  - Bumper Sticker
                    So YOUR to blame for people getting pulled over! It's all your fault! (If lights don't work the red and blues don't flash Haha)
                    I've heard of noise comming from wires too, if the insulation isn't thick enough, but I doubt that's the case here.
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                      Youd be surprised how many times I've seen blinkers, horns, lights, etc not work because of a ground on a light bar. UGH. I grew an honest hatred for the interior of a Dodge Charger doing that job.
