So I bought a cheap headunit from walmart and this wiring harness
But after wiring it up (Matched corresponding colors between the two harnesses like I have 10 times before) and nothing I'm not getting any power to the unit and now my door buzzer starts going when i turn the key. From reading some of the wiring posts I know that I need to ground the black wire from the HU harness as its connected to nothing as there wasn't a black wire on the harness but what is causing the open door horn to go off.
Also my "cigar" fuse is blowing everytime i turn the key but is an exposed wire not connected to anything cause the PO cut off the cigerette lighter or something weird.
Attaching a pic of the harness as my colors don't match up with the stickied thread.
