installing a radio
  • installing a radio
    ok need to know how to hook a radio up in the festiva.... i only got ground and the radio antenna nothing else.... did confirm that there are 4 speakers but can't for the life of me find the speaker wires and constant "Memory" power need help
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
    This is what I found on google..
    Car Radio Battery Constant 12v+ Wire: Blue/Red
    Car Radio Accessory Switched 12v+ Wire: Red/Black
    Car Radio Ground Wire: Chassis
    Car Radio Illumination Wire: Blue/White
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 4″ Speakers
    Car Audio Front Speakers Location: Dash
    Left Front Speaker Positive Wire (+): Blue/Red
    Left Front Speaker Negative Wire (-): Blue/Yellow
    Right Front Speaker Positive Wire (+): Blue
    Right Front Speaker Negative Wire (-): Blue/White
    Car Audio Rear Speakers Size: 4″ Speakers
    Car Audio Rear Speakers Location: Shock Towers
    Left Rear Speaker Positive Wire (+): Blue/Red
    Left Rear Speaker Negative Wire (-): Blue/Green
    Right Rear Speaker Positive Wire (+): Blue/White
    Right Rear Speaker Negative Wire (-): Blue/Green
    may help but does the car still have the factory wiring plugs?
      It has a dimmer. Its Orange iirc.
      06 Jeep Cherokee Overland
      95 Aspire (sold)
        They probably didn't list the dimmer wire because most aftermarket radios do not have a wire for the dimmer switch input.
          Everyone i have run across did. From the Wal-Mart special to my 600 dollar jvc they all have it.
          95 Aspire (sold)
            The Festiva speaker wires are predominantly green for the front and blue for the rear. See if you can locate all eight of them. They should be in two bunches of four. Memory power is a single white/red wire with a brown connector. Good luck.
              i only got a solid black wire but i don't know where it goes (maybe to chassis someware?) also got all 4 speakers in the car.... i will check the wires later when i get home
                didn't see the plug... looks too clean behind the "1980" 2 knob radio i pulled out yesterday.... he said he did not know if that radio worked he just used it to fill the hole in the dash
                  The solid black wire grounds the radio to the dash frame.
                  Normally any solid black wire is a ground.
                    ok well i saw the radio antenna and ground i will look later for other wires
                      May be most of the ones i have installed never have them but mainly i use pioneer or kenwood radios i can not remember if my old double din from jvc had the dimmer wire or not because it was in the car when i bought it so i am not certain.
                        well after i looked yesterday, i gotta run new constant and swiched power to the dash plus i gotta find the speaker wires and bring them back into the dash... btw how do you remove the speaker grills?
                          This is the one i currently have and it does.
                          95 Aspire (sold)
                            i second my quote because somebody really hid the radio wires good!
                              Pry them up from the bottom with a flat-blade screwdriver.
