what size/kind of subwoofer and amp do you have for your festiva.... I got a very basic 12" sub and box but need a compatible amp, and somebody who knows what their doing to install it....
What subwoofer size do you have?
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
well my sub is 12" and 400 watt max NO RMS..... need to find a good amp for itLast edited by old yellow; 11-17-2014, 04:34 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
300 w eclipse amp, with an infinity 8 inch sub, custom box I built, very compact, very clear.-Greg
Redneck Engineer
FOTY - '09
Typically the rms power handling of a speaker is "about" 1/2 of the max rating. BUT that also depends on what you are listening to and how you listen to it. Distortion is the enemy of any speaker and quality power delivery will allow the speaker to handle power a bit higher than its rating. It is impossible to recommend anything with the info given. What music? How loud? How much money? What type of enclosure? What kind of car (assuming Festiva here lol)? What kind of charging (also assuming stock Festiva alternator)? And most importantly, what is the speaker impedance (you cannot buy an amp without knowing this info) and how is the quality of the install? These are all proper questions necessary to answer your question best.Originally posted by old yellow View Postwell my sub is 12" and 400 watt max NO RMS..... need to find a good amp for it
I like to overpower all of my speakers. BUT I also have an oscilloscope to properly set all of the gains in the system starting at the source. The amplifier gain is not a volume control as most people think. It is a level matcher. Designed to "match" proper volume levels of all equipment in the chain.
If I were you I would search for a a smaller single channel amplifier with a power output of around 200-250 watts. I will say that there are a lot of brands on this planet and any number of them are capable of doing quality work. Don't get cought up in the brand war that this can turn into. If you want you can pm me and I will give you some good recommendations.
Run a good "Quality" 8 Ga wire and make sure of a PERFECT ground connection (very important). Use a good set of RCA's. A good wire kit will run you about $40-60. A lot of guys here will say get the cheap stuff but I will say the difference IS noticeable. Please let me know if you need more help.-Bryant
12" Rockford 480rms amp 1000peak Sony amp in a Wally world box.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I already have the sub and sub box... free but I just have stock 4" speaker which are Kenwood brand now but I would want the corner speakers to be for Mids and Highs and have the sub do all the bass... my radio does not go loud enough for the 4" speakers to have distortion, so I think i will be okOriginally posted by Gomez View PostTypically the rms power handling of a speaker is "about" 1/2 of the max rating. BUT that also depends on what you are listening to and how you listen to it. Distortion is the enemy of any speaker and quality power delivery will allow the speaker to handle power a bit higher than its rating. It is impossible to recommend anything with the info given. What music? How loud? How much money? What type of enclosure? What kind of car (assuming Festiva here lol)? What kind of charging (also assuming stock Festiva alternator)? And most importantly, what is the speaker impedance (you cannot buy an amp without knowing this info) and how is the quality of the install? These are all proper questions necessary to answer your question best.
Run a good "Quality" 8 Ga wire and make sure of a PERFECT ground connection (very important). Use a good set of RCA's. A good wire kit will run you about $40-60. A lot of guys here will say get the cheap stuff but I will say the difference IS noticeable. Please let me know if you need more help.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
The 4" speakers are pretty good down to about 4-500hz minimum. And that is with a proper crossover installed. Now depending on how loud you listen to your music and the quality of sound you want, you should be good with installing a simple 100mf capacitor in series with each of the 4 inchers if you are hooking it up to your radio. That will give you a 6db/oct crossover slope starting at about 400hz. That will keep unheard distortion to a minimum allowing for less listener fatigue (really nice when on long trips). Then set the crossover on your sub amp to somewhere around 150-200hz Low pass. these are not optimum settings for either speaker since there is a BIG "mid-bass" gap with the size difference of your speakers.
I tend to be a bit pickier than most people with sound. I hope I am not giving too much info or taking away from your thread. I just want you to have the best possible sound with what you have already. Every speaker needs a crossover to operate within the designed parameters.I just like it when people ask audio questions. I wish there were more people into it like there used to be in the mid-late 80's to late 90's. Those were some fun times.-Bryant
I would also suggest trying to separate the front and rear of the speakers in the stock locations as much as possible. Foam baffles that surround the speakers themselves really do make a huge difference in the sound of even a stock speaker.-Bryant
Good info!-Greg
Redneck Engineer
FOTY - '09
Nicely put. Any real audio guru uses a scope to see what's really going on.Originally posted by Gomez View Post..... also have an oscilloscope to properly set all of...... .
And I use one for digital projects too. Amazon has awesome pocket sized dudes.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
