I know what wire goes to what but where does it go on the rear of the stock radio?
Sent from my iPhone 5s using Tapatalk
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED! '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look forNarion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD! R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
The four blue wires are for the front speakers and the four green wires are for the rear speakers. There are two X four terminal connectors on the back of the radio. You have a 50:50 chance of guessing it right. The other two connectors are for juice in.
this diagram doesn't reflect the actual layout and both FRNT and RR 4 blade recess looks like they would accept either connector. but using positional logic, turn the diagram 90 degrees right and it sort of follows the radio layout. i'm betting the 4 blade gang to the right of the single blade in your pic is for the front speakers.
ok so rotate the diagram 90º clockwise? The 4 vertical plug is the front speakers and to the left the 4 horizontal plug is rear speakers? and on the 3 pin plug the right horizontal plug is switched power? and single plug is constant power?
old, just guess and plug in one four terminal connector. If the sound comes out the wrong speakers, then plug it into the other socket and don't buy any Powerball tickets for a month.
ok thanks I will figure it out one day when dad doesn't work and I have time
