So I designed and built this sub for my new festiva and thought I may as well post the plans here for anybody else who wants a nice big sub.
It's a LAB15 driver in a 3.3cuft box tuned to 33hz, max SPL is around 120db, and I'd recommend an amp that can do around 600-1000w at 4 ohm.
This particular driver was a 4 ohm version of the LAB15, if you use the 6 ohm version you'll need an even more powerful amp to get the voltage it needs.
I designed it to replace the back seat, it bolts down using the front-side rear seat mount bolts with L brackets, and I'd definitely recommend bolting it down because you don't want this flying around in a crash or something.
You may have to drill holes in the floor to bolt the back side of it down.
I used plywood in the build because it's lighter and more durable than MDF, and weight is an issue with a box and driver this big, IMO at least.
Tips for assembly, use a nail gun with 1.25in nails to hold everything together as you go, this way you can get it all done without waiting for any of the glue to dry.
Glue, clamp, nail, remove clamps, move on to the next joint.
As for glue I recommend loctite PL premium, it's super sticky and messy but it's the best glue for making speakers IMO, it expands and fills cracks so you don't have to worry about leaks and your cuts can have more slack in tolerances.
Don't try to wipe the glue off before it dries, the stuff that squeezes out of the gaps can either be scraped off carefully when wet or it's best to wait a bit then use a scraper to take it off.
Trying to wipe it off is just going to make a huge mess and you can't remove the stuff with sand paper later, it just doesn't sand down.
I like to leave a slight bit of overhang on all the corners where the wood meets up, then use a flush trim bit on a router to bring it in clean and flush.
I've included the winISD model of the enclosure for this driver, the cutlist in PDF format and the sketchup file so you can look at it before building.
I ended up not installing the cross brace below the driver, just be aware that you shouldn't block the pole vent on the back of the driver and keep driver depth in mind.
Pics of the build: http://imgur.com/a/iIYQf
Cutlist, windISD and sketchup files: https://u.teknik.io/BPmEYg.zip
