Radio power plug wiring
  • Radio power plug wiring
    Two of the three power wires are broken off the radio plug.
    Only the red with black stripe wire is connected to the plug.
    Does the white with red stripe wire go beside the red wire or below it?
    Does the blue with yellow stripe wire go beside red wire or below it?
    Thanks David
    The stock radio power plug for the tuner is a single white/red wire in a single brown connector (from ROOM fuse).
    The stock tuner lamp connector C206 is a three position connector. The lower horizontal position is not used. It becomes live when the radio is turned on and would most likely have been used for a power antenna relay.
    The other two wires are side by side. Blue/yellow (from CIGAR fuse, hot in Accessory or on position) and red/green (dimmer) looking into the plug with the tang down.
    Pull the fuses before crimping on some new open barrel terminals.
      Thanks Bravekozak.
