Custom Low Key "System"
  • Custom Low Key "System"
    Had a thought. Nowadays smartphones are the norm, and bluetooth speakers are cheap. One could totally delete the head unit, install some speakers in the stock locations so nobody knows jack, and then you'd have your selection of music with nothing showing you have anything. I imagine the quality for those who care a lot about that would be sub-par, but I'd say a lot of us aren't that deep into it.
    I bet it would be great. Seriously considering doing this.
    ..... awaits updates
      What are you thinking, a small bluetooth receiver wired to an amp hidden under the dash?
      91GL BP/F3A with boost
        Nah, a cheap 2.1 factory Bluetoothed set of speakers and a phone.
        Like this.
          This is what im going to do with my car.
          19?? 150$ burnout car SOLD
          1991 (STRESS RELIEF)SOLD
            Fecomatter has an amp with speakers that he plugs his phone up to. HIde an amp under the dash as Brad said, and you don't have to drain the car battery and lose sound quality to BT.
              Honestly you would waste money on those bt speakers. Only reason I don't have a head unit is because my Extra one just didn't work in the Festiva. Idk why. If you cheap out on crap bt speakers, I'm guessing the sound quality will be in bearably poor. If you still don't care, I'd bet you will not be able to get them loud enough for cruising. Just hide an amp, Wire that you your stick speakers, the buy s bt reciever to wire into your car switched power.
              Tommy
              WannaBimmer Build in Progress:
              http://www.fordfestiva.com/forums/sh...-Festiva-Build
                ya I barley hear mine with a basic head unit and stock size speakers and when I do hear it it's distorted.... need to install some bigger component speakers in mine.... the Bluetooth speakers I imagine would be hard to hear or distorted....
                Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
                Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
                Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
                it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
                Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
                TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
                bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
                '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
                SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
                R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
                R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
                R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
                R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
                R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
                  Replaced all my speakers with fosgate 4”. Paired with a $55 pioneer head unit all for under $100 on Amazon. I use all of the factory wiring that was already in the car and a $7 ford wiring harness. Only have to re-pin 2 wires. Sounds really good. Might get a $100 sub set up on amazon soon. Awesome sound system for under $200.
