Glass work?
  • Glass work?
    Has anyone done any fiberglass work to your festiva? Custom door panels, custom kick panels, or even the dash? I'm currently designing my door panels, and the center console. I jsut wanted to know if anyone has tried anything like this? As soon as i get done, i will post picks of my handy work.
    "If it's too loud, Youre too old!"
    Get in, sit down, shut up, and hang on!"
    that makes 2 of us.. The mdf is way too heavy.. so I have removed everything and am in the process of designing a new fiberglas interior.
      Good luck, Fiberglass can weight as much a mdf, just depends on how may coats you put on. also, make sure to reinforce you sub enclosure with something. Fiberglass can and will flex, giving you a funny sound if all of youre box is made out of it.
      my .02 worth
        you must be using waaay too much glass if it's as heavy as mdf... that stuff weighs a ton!
