could you swap out the festiva's injectors with something bigger like those out of a 1.9 escort engine or something?
new injectors
^^Yes why?
What are you trying to do?Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
a little more fuel, combined with a little more air = a little more power1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
2000 Trans Am 6 speed
1997 HD 1200 sportster
1986 Honda Rebel 250
So your going to Turbo your B3?Originally posted by smokin fastivaa little more fuel, combined with a little more air = a little more power
to be honest you would likely just run rich because your ECU doenst relize full open on the injectors isnt the same amount of fuel as they are with the smaller festiva injectors, as far as NA motors are concerned, unless your running ITB's you will likely never max out theones that are currently in it now.
now if you ARE going turbo, you WILL need larger injectors, i reccomend the injectors from a turbo 626 or probe GT turbo as they are 330cc compared to the stock 180's i believe? should be well more than enough for a stock b3 block and any boost it could handle.
i myself am running 550cc denso injectors controlled by an aftermarket Emanage unit which can control fuel cut or add every 500rpm from 18a/f down to 10.
anymore input on the engine/plans and i could give better info.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
I don't think ppl realize when you increase injector size they spray more fuel all the time, that means at idle your % increase will be the same as at wot 6000 rpm. In other words you will flood the motor before it can even start it.
Question should be what injectors and fuel management do I need?
Worst part is you will use alot more gas and be wasting it, but its your money to burn.
Thanks
