hay guys, I finally checked the code my car was intermitently throwing, it was either 18 or 8, I don't know, when I turned the key forward with the test lead grounded, all the lights came on(including the CEL) and then the CEL went off for a good 3 or 4 seconds and then it came on flashing and flashed 8 times, so is the initial turning of the key when you start counting or do you wait till after it went out the first time from turning the key forward, then you start counting after it starts again, also does anyone know what these codes are? its an FI b6 with the B6 ECU out of an 89 323, I don't know if the codes are the same for the 1.3, but I lost my haynes anyhow so I guess it doesn't matter
thanks :wink:
thanks :wink:
