Adjusting Clutch Cable
  • Adjusting Clutch Cable
    How's the clutch cable adjust? I know by the screw on the tranny fork...
    Here's my scenario: I hard accelerate in 1st and slam into 2nd, get on it and all the thing does is "slip" - ie. it doesn't make the car move.
    My only thought is that maybe the cable is not properly adjusted after the new tranny... All the other cars that I've driven with a performance clutch have always broke about a 1/2 from the beginning (meaning, I put the clutch in the whole way to shift, let it out a 1/2" and it's engaged) - with MY setup, I need to let it the whole way out, but it does nothing until that last 1/2"...
    How do I adjust this so it stops slipping and so that it will engage at the very beginning?
    My dreams of auto-xing this weekend are starting to dwindle!
    Simon - pimptiva.com
    Righty Tighty....
    1991 L 408,000 miles+ w/NEW B3 longblock!!
    2008 Nissan Versa S HB
      no, you wanna loosen the nut on the end of the cable to tighten the clutch, you want the pedal to go down a little bit before the clutch starts to disengage
      i did this not too long ago
        Yeah, I see your right Damkid now that I think of it. ops: He is running with no free play and the throw out bearing is basically riding the pressure plate all the time and not allowing a full hook up.
