Ok, just got finished moving my 89 b6 from my old 90 festy, into my 97 aspire. I had previously upgraded the older vac. advance style distrib. to the newer 90 style festy distrib. Was also running a (2 plug) b6 computer. The newer style (97) tps is completely different, and will be needing some engineering to get it go onto the older throttle body. In the meantime, the older tps, is in fact working! It doesn't like it and it did set some codes. I've also reused the aspire distributor, and the aspire b3 computer, and it's running amazingly great. I've got a narrow band air/fuel gauge that's telling me it's running slightly richer, which is good, but I can't smell any extra gasoline at all. I've got to change out the temp sensors, looks like possibly the gauge sensor has a different range to it.
But now for the really great news:
Got my Phantom Grip LSD installed and I've been driving it around.
I've been able to test it on pavement, wet pavement, and dirt roads and I'm here to tell ya, it way hooks up! This without any breakin (seating)time, but you'll understand why later. First things first. I got the #906 gold, the "gold" designates the "spring tension" option. The gold springs are "standard", the green springs are stronger yet, and are optional. Apparently they actually make an optional weaker spring? My goal was to achieve more grip on wet roads, snow, and ice. If you're drag racing or autocrossing, maybe you'd want the stronger green springs? Also, so far, torque steer is completely gone! I took it out on the dirt, cranked the wheels all the way left and hammered it. Both of those wheels just clawed and chewed continuously, think fat girl at a buffet! The way this thing works is, it "locks" the two side gears together with spring pressure. Not a 100% lock, or you wouldn't be able to turn, but keeps/prevents that old "one wheel spinning" from happening. You cannot feel it when you're turning, it's just smooth and torque steer free! That "one wheel spinning situation" IS what eventually grenades transmissions. AVOID IT! I've seen that on more than one occasion, especially on the ice. I can't wait to see what happens as the ice and snow conditions arrive.
And now for some pics:
This is what the trans looks like open:
Here's pics of diff carriers without and with the lsd:
This unit does not just "drop" into "our" carriers, I'm sure some of the larger units might get a little luckier than us. I actually had to do quite a bit of machining, 30 thousands off of each of the two pinion gears, and 30 thousands off of two sides of the lsd to create a total of 120 thou. of space. I'm using 115 with 5 for oil.
You'll also have to take some off the side gears as well, (this is where the real friction happens) Phanton Grip actually suggests a belt sander as an option, but I spent the money for the exellent flatness only machining can provide. The next two pics are of two side gears "before" and one pinion gear and a side gear "after":
The total cost for this deal was: $256 for the lsd (online store), $75 for machining (local shop), and $90 for cryogenic treatment of 4 gears, 4 thrust washers, and 1 pinion pin (300 below, Il).
Now of course, I did all new seals in the trans, and new end bearings on the diff carrier, ($30 for the bearings). The rest of my bearings were good, (150,000 miles) on this trans.
The removal, dissasembly, reassembly, and reinstall, all done by your's truely: priceless
