The b6ZE(RS) 89-93 maxda miata 1.6 dohc 16 valve
The b6-E 86-89 mazda 323 1.6 sohc 8 valve
I know the bore and stroke are the same 78x83.6mm some I'm assuming i can use the pistons without a problem, want to try to hit 10.5:1 compression. But the big question is the crank....the miata crank is the lightest out there of that year with the flywheel to produce a 7200 RPM redline. I'm hoping they're are the same because I'm gonna start looking for one.
