Gears in the Trannys
  • Gears in the Trannys
    Hello Guys,
    I was reading the transmission swaps for the Festiva, then I got to thinking: Can you interchange the gears through the trannies? I know, at least with the MR2 I have, I can put a 6 speed in my car by just putting the gears out of a Celica. Plus, I lack a welder or know anyone with one.
    Current cars:
    the aspire trans will bolt right in, the 323 tranys will bolt onto the engine but you'll need custom axles made, and the EGT 1.8 trans will also work save for axles. i know there are others, but don't know the specifics.
      That wasn't really the querstion. I know they all mount up to the motors, I just can't really get brackets welded for the car, thats why I was wondering if, say, the G series gears would go into a E-series casing.
      Current cars:
        short answer: no
        But Aspire gears will go into a Festy case.
        Jim DeAngelis
        kittens give Morbo gas!!
          Are the Aspire gears any stronger?
          Current cars:
            no, but the final drive is steeper.
            Jim DeAngelis
              You could send the gears to a place in Il. called "300 below". They cryogenically treat things to make them wear much longer. I sent then my diff gears, both side gears, the pinion gears, pinion pin, and thrust washers. Very great to deal with. You could send them everything. Go read about cryogenic gear treatment, see if that will fit you needs. I consider it to be a good value.
                I wish you could cryo the case... LOL.. My gears seem to hold up, but the friggin case splits...
                My Website:
                Car Domain:
                My Garage Page:
                  Actually, you can sent them the case! And this service is by the pound, so that's no weight. Racing teams send them pistons and turbo housings all the time too.
                  What's happening that you're wrecking the case? You're not trashing the diff pin are you? You know once you do the bearings, you're suppose to shim the slack out of everything.
                  BTW I've got a festiva case I can let you have for cheap.
                  P.M. me for a picture if you're interested.
                    This is what I did... too much wheel hop, ALL my bushings/mounts, trans/control arm/engine were soft and worn out.... I replaced the trans, and all the mounts and bushings with high durometer units.. I hope to not have that problem any more...
                    My Website:
                    Car Domain:
                    My Garage Page:
                      auto x is hard on the drivetrain to begin with though lol
                      92 GL - parts car
                      97 aspire - parts car
                      87 323 DX - daily driver
