i have heard that there is a 4cyc Mitsubishi engine that will drop in and bolt up to a festive i am trying to find out if this is true any info would be a great help
mitsubishi powered festiva
The 4g63t from the first generation and second generation Mitsubishi Eclipse would be closest to our normal BP swap.
However I do know that it would require modification to mount it, and you would need the transmission, axles, wiring harness, and ecu to go with it.
But with that transmission there is the possibility to AWD our epic little cars.
