My 1993 with 343k miles , probably around 200k on current motor has been leaving me itching for brake upgrades due to warped rotors and pain of turning them , and read drums being too small to fit on the brake lathe. I just recently got my AC back working and tinted all my windows. Always said I love this car and will try to keep it forever.
So I stumbled on a 2001 kia sephia 5 speed with around 70k miles for $550 with a completely trashed clutch or so it seems pretty sure all it can be since I get resistance to go into all gears without clutch pushed , so rules out a sheared input shaft and so I think any other issues unless I'm overlooking something. Was driven 30k miles by their son who learned how to drive a clutch on it and now it won't budge in any gear can let it run in gear.
Plans are to fix the clutch with a stage 4 and a new flywheel and fix whatever else I see needs fixing and drive it sometimes till I restore my truck so I can park both it and my festiva while I do a swap which I will have a better idea with both cars side by side , buying the car tomorrow.
1.8l T8D , pretty close to the BP
125hp , 107 torque
Ventilated larger front rotors
Slide off rotors
Bigger rear drums
Rear drums are seperate from wheel bearing
Independent rear suspension cradle
4x100 bolt pattern 14" wheels
A arms instead of a single lower control beam
Not 100% sure can do the complete swap , but I don't mind modifying , cutting , fabricating to make it work if it's within reason. But too good to pass up so might make a build thread at some point.
125hp , 107 torque
Slide off rotors
Bigger rear drums
