I'd like to lower the cruising RPM of a stock Rio by swapping in a longer 5th gear and final drive. I apologize that this isn't directly Festiva related, but the Rio has little enthusiast following on the internet. Since it's the successor of the Festiva/Aspire, I was hoping to tap into your community's knowledge.
Is the Rio transmission a derivative of the Mazda F-Series or G-Series transmission? The Festiva and Aspire used F-Series transmissions (right?) so I assume F-Series. The best donor candidate looks like the 1991-1996 Escort 1.9l transmission, but the bell housing and axle splines seem wrong. Will the guts of the 1.9l Escort transmission fit in the case of the Rio transmission? To avoid sourcing new axles, do you think I could swap the old spider gears into the new differential?
Is there a better direction to take? Is the Rio engine/transmission combination a unicorn with no swap potential? I appreciate any help you can offer.
