engine parts interchange?
  • #16
    you probably can use it RWD, if its carbed then no worries with the intake I guess... just make sure you swap the oil pan and oil pickup or it will starve the oil pump cause the engine is tilted rather than being flat... I know the Miata guys that wanna go BP miatas will sometimes use the BPs out of the EGTs and swap over the oilpan and intake to use it as RWD in a miata, so I don't see why you can't do the same thing with a B6SOHC
    No festiva for me ATM...
